Pulleys? Need Help!
Old 05-04-2001, 10:27 PM
64 f100's Avatar
64 f100
64 f100 is offline
Pulleys? Need Help!
Old 05-09-2001, 08:39 AM
darkman's Avatar
darkman
darkman is offline
Pulleys? Need Help!
Ok I know someone knows the answer to this simple question. The dampner pulley on most Y-Blocks was a single sheave and if you added power steering to a car it would have a separate single sheave pulley which bolted to the dampner. I want/need to run a dual sheave dampner for a/c and Ford does in fact make one. I need to know will the p/s bolt on pulley still work with the dual sheave dampner?
Thanks Charles
Old 05-09-2001, 10:46 AM
William's Avatar
William
William is offline
Pulleys? Need Help!
Charles! You will have to look in the Junk Yard for the pullies you need. Ford used many different combinations over the years. The aftermarket AC on my truck had a bolt on pulley.
William in Atlanta
Old 05-09-2001, 09:29 PM
darkman's Avatar
darkman
darkman is offline
Pulleys? Need Help!
I'm trying to find a setup that is factory that will mount the compressor above the generator and on the passenger side. I want the most compact system that Ford offered on the Y-Block. anybody have any ideas? I haven't had any luck at the salvage yards.
Thanks Charles
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Pulleys? Need Help!
