Bronco Ignition Coil Mount
My friend has an 84 Bronco. At some point, the engine was replaced. A 351 was installed and someone installed a later style distributor (the one with the module attached to the distributor) and a home-made wiring harness. It has the square-type coil, which is currently zip-tied to the air conditioning bracket. What is the correct way to mount this type of coil? Can someone post a picture of the mount? Thanks.
loksoff
20
12-03-2013 06:17 PM
cujo8
04-08-2008 08:26 PM
