1984 300 msd ignition dilemma
Alright fellow Ford drivers.. this is my truck
1984 f150 w/ 4.9l motor
- 4wd 4 spd tranny
- offy dual plain intake
- holley 390 cfm with vacuum secondaries
- efi exhaust manifolds with two into one pipe straight to crusty (original?) muffler
- MSD 5520 Ignition Module with an MSD blaster Coil
I don't understand why you get a spark when shorting the pickup coil.
The pickup should read 400-900 ohms across orange and violet.
When the reluctor wheel sweeps the pickup it provides a pulse that triggers a transistor in the stock ignition module.
Is the air gap of the new pickup set between .015-.025"?
I'll grab a feeler gauge and check that gap, but it seemed to be normal. In the msd instructions it tells ya in order to test that your ignition module and coil are performing correctly to place the coil wire near ground and to short the two magnetic trigger wires. If using the white trigger than you short it to ground.
I've never really done the MSD diagnostics, but it seems your coil and module are functioning correctly.
The only thing left is the distributor.
If it is turning with the engine and the gap is correct there is little else to fail.
Sorry that I don't have much experience working with these things.
I have installed a couple and removed a few problematic ones.
But the new installations always worked as they should.
This may not be your problem, but I can assure you that the MSD system can work well as a stand alone system [no Duraspark box] when triggered by a Duraspark distributor.
It is VERY important to connect the wires in the manner Jim detailed [ask me how I know? ]. If the violet wire is connected to the violet wire and the orange wire to the green wire [backwards], then the timing will be retarded by something like 20+ degrees. The engine can be made to run by advancing the timing, but the timing will never be correct. The MSD box gets its signal trigger off what looks like a wave. With the wires swapped, the trigger point not correct. This can cause all kinds of problems with timing to the point that the vacuum advance cannot be used [again, ask me how I know]. This may not be your problem, but I can assure you that the MSD system works well as a stand alone system [no Duraspark box] when triggered by a Duraspark distributor.
I connected the wires as the diagram called for with the violet to green and orange to violet and I got nothing for a signal. I figured the msd box wouldn't need anything else, but that was something I was just kinda throwing out there since I'm baffled. The only thing I went away from on the diagram was to connect the "small red" wire to a switched 12v (I ran a connector through the firewall to a socket on my fuse box that gets 12v when the key is turned on.) I did this bc I didn't have the duraspark harness to allow me to connect to the duraspark coil plug. Thanks for the replies guys. I feel like it's gotta be something so minor and stupid.
You need advance one way or the other.
The DSII dizzy uses vacuum and centrifugal advance.
The TFI dizzy uses the TFI itself and the ECM to achieve the same thing.
All the MSD box does is to fire the coil a few times instead just once below 3,000 rpm.
By using capacitors to dump higher voltage into the ignition coil it is able to reach saturation with much less dwell.
I don't see how that helps if the plug has already lit the charge the first time.
You need advance one way or the other. The DSII dizzy uses vacuum and centrifugal advance. The TFI dizzy uses the TFI itself and the ECM to achieve the same thing. All the MSD box does is to fire the coil a few times instead just once below 3,000 rpm. By using capacitors to dump higher voltage into the ignition coil it is able to reach saturation with much less dwell. I don't see how that helps if the plug has already lit the charge the first time.
Here's the PDF file for my ign box just for quick reference.
http://www.msdignition.com/uploadedF...ions1/5520.pdf
