forced induction threw a carb
Depends on what type of induction. Centrifugal types (turbo and supercharger) the carb comes after... positive displacement types (ie. roots supercharger) the carb comes before. Judging by how you wrote the request... the first one applies.
-Kerry
-Kerry
Older setups with blow-through carbs used a box around the carb, and a little higher fuel pressure to overcome the boost pressure.
'57 Fords with McCullough superchargers, mid '60s Mustangs with Paxton superchargers, and, get this, mid '80s Masaratis used this technology.
I did a google search with "blow through carb" and the first two up are these:
http://www.fordmuscle.com/archives/2...arbs/index.php
http://www.stevemorrisracingengines....b-engines.html
Get your checkbook out.
The pressure differential created when the air flows thru the venturi (Bernoulli principle) in the carb is what forces fuel out of the float chamber and into the air stream (no sucking involved). The bowl vents in the carb throat keep the pressure in the fuel chambers the same as the pressure of the air stream. The fuel pressure must also be higher and regulated by the boost pressure. It is a complicated setup but has been done many times.
Personally I think it would be fun!
Yes you can boost thru a carb. I have a picture of my setup in my gallery. Blow thru carbs are available or you can modify your own. The best site I have found for information is http://www.turbomustangs.com.
And yes Torque1st 10lbs of boost is a BLAST!!
300/6 Freak
83
11-24-2019 12:32 PM
pinehillian
01-09-2017 03:02 PM
BuiltFordTough100
24
06-01-2012 01:43 PM
CalebJns
17
04-29-2011 06:47 PM
air, blow, carb, carbs, carburation, carburator, carbureted, carburetor, carburetors, forced, ford, induction, methanol, roots, supercharger, work
