new guy with turbo ranger
Old 09-06-2006, 06:13 PM
Dave257's Avatar
Dave257
Dave257 is offline
Duh, someone just hit me in the head with a small block chevy...I would still start it without the valve cover (Oil everywher be dammed) and see which one is ticking.
Dave
  #47
Old 09-06-2006, 09:17 PM
turboranger91's Avatar
turboranger91
turboranger91 is offline
60psi. of oil pressure would put oil on my neighbors car, haha!
  #48
Old 09-07-2006, 11:14 AM
Eric.S's Avatar
Eric.S
Eric.S is offline
o well, just make sure to charge him for that special anti rust coating
  #49
Old 09-07-2006, 11:32 AM
Dave257's Avatar
Dave257
Dave257 is offline
Years and years ago I sometimes had to adjust valves at the track between heats. I had a set of small block chevy covers I had cut up so I could get to the valves and adjusters but still covered most oil supply holes. The worked pretty good and I sold several to fellow racers. Then someone came out with a set of clips that blocked the oil spurts. You really can feel a loose valve. Anyway, just an old goat rambeling..
Dave
  #50
Old 09-07-2006, 01:38 PM
pud's Avatar
pud
pud is offline
what about the cam bearings? Sure its not a small exhuast leak between the the head and the DP? Ive heard some funky sounding exhuast leaks that sounded like lifter noise. Another suggestion: I had an 88 mazda mx6 (steal of a deal, couldnt pass it up, traded it for a stang) they 2.2L had HLA's, hydraulic lash adjusters. These were known for clogging up and not taking up the slack in the valvetrain, which would cause one hell of a racket. I dont know much about them, other than they were a problem...Im a pushrod kinda guy..but maybe its something I mentioned, at least you can check if you havent.
oh and BTW....stock vs stock, the 4.0L might be ahead, if its lucky, untill the 2.3L turbo hits 3rd.
p.s. turbo ranger guy, have you seen this site? http://www.projecthp.ford23.com/ the guy is a member at stangnet.com in the 2.3L section, he has developed alot of 2.3L parts, DP's, header, intake, and other doo-dads.
  #51
Old 09-11-2006, 07:35 AM
turboranger91
Originally Posted by powerdog
www.rangersrevenge.com
I am about ready to drop in the new built motor. Waiting on the machine shop. It will be spinning the rollers in 2 weeks. Right now I have over 2K invested in just the motor.
2.5L crank
Crower rods.
Wiesco pistons.
Large valve head fully ported.
Head studs
Main studs
Total seal rings.
1035HG
2277 ESLINGER roller cam.
60lb injectors
90mm MAF.
Plan to upgrade to. c4 with 3k stall street-fighter converter.
I have the tranny just need to drop it in after the stock 5spd blows.
LARGE HYBRID TURBO or HOLSET hx40 will be used. I have a few holsets and some hybrids laying around not sure if any are good for the 500+ mark.
I am hoping for 400+ RWHP. With some IC upgrades and larger injectors 500+ I hope to run next race season in the 10's I will try to make a few of the fun ford weekends.
It will be a full winter's work to building the chassis.
jess! i know all about your truck, man. and you actually know all about mine too. i'm GenIIRacer on RPS. small world, huh. nice to see a friendly face.
  #52
Old 09-11-2006, 04:17 PM
powerdog's Avatar
powerdog
powerdog is offline
Hey nice to see you on here. Sure is a small world.
  #53
Old 09-15-2006, 02:29 PM
turboranger91
i'm picking up an extra head this week so that i don't have to canabalize the turbocoupe. we'll give that a shot. i'll keep you guys posted on any progress.
300FOREVER
09-29-2010 05:06 PM
78superfugly
12-11-2007 05:51 PM
91 Ranger Turbo
Indiana Chapter
01-31-2005 03:25 PM
Rangerman37048
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
26
07-20-2004 02:46 PM
amp17757
22
03-13-2003 11:56 AM
Quick Reply: new guy with turbo ranger
