I'm almost certain its pressed on because I can pull the **** off on my 88. The shifter dosn't have any threads but I think its grooved to prevent movement. I just went out and tried to pull the **** off on my 97 work truck, but its too tight. You might try hitting it from the bottom up to break it free. Good luck
I was trying to get the boot off so I could pull the carpet out. Kinda spilled some Diesel Kleen behind the seats so I needed to give it a good cleaning. Ended up just removing the whole shift arm from the linkage. All good now. Thanks for the replys
