FUSE 42 - Help Please
HI,
I have an 05 Ford F150 that keeps blowing the 10Amp Fuse 42 in the passenger seat ankle level fuse box.
Fuse 42 is the LH turn and stop signal in the manual.
See, i just got a utility trailer and the right blinker works, brakes and parking brakes, but for some reason the LH parking light only works.
the LH Turn and Stop keeps blowing the fuse.
I thought it was the trailer. i checked everything and couldnt find anything. I hooked it up to another truck and the LH turn and stop worked!@@@@
So its the truck???
any help you can give would be great?
thanks
Jason
So its the truck???
thanks
Jason
Well if it doesnt blow the fuse with the trailer hooked up and does when it is...and you know for sure it is not the trailer then I would assume you have some wires crossed in your wiring harness. If it is a Factory installed system andstill under warranty I would give it to the dealer and let them figure it out.
I had a 92 f-250 do the same thing, ended up being a wire the rubbed on the steering column every left turn, the insulation wore off and the bare wire shorted out. After replacing a section of wire and routing it away from steering it was fixed. Hope yours may be something easy like this instead of some complicated wire trouble shooting
Problem still exist............dealer couldnt figure anything out..........anyone else have any suggestions.
also, with out the trailer hooked up it does not blow the fuse with left turn. only when trailer is attached.....but why would the trailer work fine on another truck and not blow any fuses there???
fireeater91
29
12-31-2019 03:05 PM
toothser
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-22-2017 11:02 AM
BigF350
1999 to 2016 Super Duty
20
03-17-2010 10:52 AM
