Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
Right Rear Blinker/Brake Shorted 08 6.4L
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-28-2017, 11:39 AM
claytonam1
claytonam1 is offline
claytonam1 is starting off with a positive reputation.
2008 - F550 6.4L - Just purchased from a neglected home - Right rear brake and blinker are shorted out. I have located the burned wire, removed all of the poor wiring back to the factory harness (wires look clean) checked & replaced fuses and relays. Both the trucks RH rear blinker and brake and RH Trailer blinker & brake are not functioning. LH rear and both LH & RH front are working normally. Any assistance would be HUGE!
Old 07-03-2017, 09:49 AM
claytonam1
Again..... any help.......hello? Now replacing SJB. I'll keep everyone informed. Hahaha
Old 07-03-2017, 02:33 PM
jimh425's Avatar
jimh425
jimh425 is offline
jimh425 is starting off with a positive reputation.
Good luck. Sorry that I can't offer much help. In my area, Uhaul places are experts at getting trailer lights working for really cheap.
Are you sure the bulbs aren't burned out? Are you using a tester?
Old 07-03-2017, 09:01 PM
claytonam1
I appreciate the input but seriously doubt if u-haul could do much with this one. The previous owner installed A-flat bad and did a very poor wiring toe in from the factory harness out to led's. 1 of the leads shorted on the exhaust and cause an additional short upstream somewhere.
I have tested the wiring all the way to the fuse Box. Either the fuse Box also shorted out or the 08's have a Flasher as some forums disagree with. Oddly enough I purchased one from the local auto store specifically for the truck. I'll track the noise to find out where the flasher is located.
Old 07-03-2017, 10:58 PM
jimh425's Avatar
jimh425
jimh425 is offline
Starting with a known good usually works out well.
Anyway, good luck again!
7charb
01-07-2018 08:02 PM
ed-g35
2015 + Expedition & Navigator
06-27-2017 09:42 PM
matthew smith
1968-2013 Full Size Vans
12-16-2016 05:35 AM
cityjack
03-19-2016 09:58 PM
Pinzer
Large Truck
02-12-2016 10:38 PM
Quick Reply: Right Rear Blinker/Brake Shorted 08 6.4L
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
