Code P2623 - Injector control pressure regulator circuit open
Old 07-21-2006, 04:36 PM
lonesta5's Avatar
lonesta5
lonesta5 is offline
I get this code when my Superchips Flashpaq is programmed in Performance, Economy, or Tow Safe mode. Sometimes extremely hard to clear, but always comes back either immediately or after a short bit of driving. Truck seems to drive fine, no symptoms other than the code.
If I reprogram to Stock, it doesn't happen.
Any ideas? ('03 F350 6.0 Powerstroke)
Old 07-22-2006, 11:34 AM
CanadaGuy's Avatar
CanadaGuy
CanadaGuy is offline
Your tuner is probably taking control of the IPR causing the PCM to see a fault.
Old 07-24-2006, 08:37 AM
lonesta5's Avatar
lonesta5
lonesta5 is offline
Continued problems with the P2623 code
I took a long (several hundred miles) trip this weekend and ran through all 4 modes (Stock, Tow Safe, Economy, and Performance). Stock is the only one that doesn't throw the code. In addition, I noticed on the last test (Tow Safe) that the truck showed a P1000 (more driving needed) in ADDITION to the P2623 even after a 200+ mile span of start/stop/highway speeds/idle/city driving mix. So I reinstalled the Stock programming and am at the point of returning my Flashpaq to Superchips.
I wonder if the factory flash in my truck (very recent) is incompatible with current Flashpaq tuning?
FYI, my existing stock Engine & Transmission
calibration codes according to the Flashpaq are:
Engine VXAP1N6
Transmission TQAT0NA
Old 07-26-2006, 07:52 PM
CanadaGuy's Avatar
CanadaGuy
I'm sure that alot of people are going to disagree with me when I say that the best tuner, is no tuner at all!
Old 07-27-2006, 07:21 AM
vloney's Avatar
vloney
vloney is offline
I'm with you canadaguy---I've been shot at before
teufel
03-07-2016 07:09 AM
danboy282
Bronco II
02-29-2012 06:35 PM
CdnArmyGuy
10-08-2011 10:34 AM
BiltFordTuff
07-23-2011 04:53 AM
Deadman2891
07-17-2004 10:39 AM
Quick Reply: Code P2623 - Injector control pressure regulator circuit open
