North Carolina Chapter Join Chapter, Leader:Benztechnc
I blew my tube "again"
Old 07-16-2006, 04:06 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
boost guage hit 31lbs on the way home from the meet, and boom blew off the IC tube again. I must have a bad clamp or something
Old 07-16-2006, 08:15 PM
ncfirefighter46's Avatar
ncfirefighter46
ncfirefighter46 is offline
DUCT TAPE IT there man LOL
Old 07-16-2006, 08:38 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
hey john i found you a calender look in my gallery
Old 07-16-2006, 10:18 PM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
SCWIDVICIOUS is offline
lol that poor tube..
31 pounds....how high can it go?
I noticed that little cobra in your gallery..sweet.
Old 07-16-2006, 10:33 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
WOW Again.
Old 07-16-2006, 10:35 PM
SuperSnake's Avatar
SuperSnake
LMAO we need to send that calendar picture to Big Mike.
Old 07-16-2006, 10:36 PM
slash31938's Avatar
slash31938
slash31938 is offline
did it scare any mexicans this time?
use some JB weld and zip-ties, thatll hold anything.
Old 07-16-2006, 10:53 PM
SCWIDVICIOUS
well....most anything...lol
Old 07-16-2006, 11:02 PM
slash31938's Avatar
slash31938
it held the rear freon line on my dads old astro van for about a week or so, and then i think the oils in the freon might have corroded or compromised the seal.
i just wish JB weld could effectively do some of the things they say it can, like fix frame cracks, and hinder a ship taking on water.
Old 07-16-2006, 11:05 PM
SuperSnake's Avatar
SuperSnake
HHHHMMMMM Sounds like Slash wants to blow something up or break it so he can fix it with JB Weld and Duct tape.
Old 07-16-2006, 11:09 PM
SCWIDVICIOUS
I use this stuff called magnum steel. Its about the consistancy of plumbers putty at first, but when it hardens, you can do anything to it.
I even used it to fix cracks in my old cobra's valve covers near the bolts. They had been tightend up too much. that stuff withstood the heat, and the oil. Never leaked again. It stayed on there for over a year till I built it up. then I had to go to taller valve covers. I used it inside of the valve covers by the way...
Also, in the intake, the rear port has a metal line fitting stuck in it. I crammed some magnum steel in it, and it held up for years. Still in there too. that fitting is made for a 5/8 heater hose to hook to.
I also used it to basically putty some chips in my concrete floor beore I did that quickcrete floor covering. thats just a few things iv used it for...
It can be tapped, milled, sanded, hot, cold, in oil, Very high tensile strength! it really dont matter. Its very good stuff. I always get it at advance auto. about 3 bucks a tube or so. Just cut off how much you need, mix it up and you have about 5 minutes to work it.
Old 07-16-2006, 11:10 PM
slash31938's Avatar
slash31938
i guess i can just rely on JB weld taking my junk off the trail, instead of john and his 90,000 lb trailer.
simsbud
07-14-2011 06:25 PM
ff1210
04-04-2010 11:16 PM
phish555
06-14-2009 11:17 AM
Red Star
Ford vs The Competition
05-05-2007 03:01 AM
KeelarPluto
02-29-2004 12:43 PM
Quick Reply: I blew my tube "again"
