got a 2006 550 my cold side ic tube blew a hole in it does any body make a after market tube that is not plastic so this does not happen again thanks??
With the metal CAC tube, you will also need at least one boot on the engine side. The metal CAC tube also has a boot at the intercooler, but I don't know if the plastic CAC tube uses one or not. Here is a picture of the metal tube and the boot from 03-04.
Good point loubell. The plastic CAC tube clamps right onto the intake elbow. I believe the new metal cold side pipe will come with new boots. I know when I bought an extra pipe for mine, it already had them installed onto the pipe. Regardless, look closely at what you have, so you know what you need to get.
