Tymar Intake
Tymar Intake
Just finished installing my new Tymar Intake. Had them powdercoat the pipe black and it looks sweet and was simple to install.
Question is though, when I pulled off the rubber intakes to the turbo, there was all kinds of oil and grit on the inside. The turbo blades were clean as was the turbo housing but I'm wondering where the oil was coming from and why?
Thanks for the info...I'm guessin the grit came from 10 years of stuff that was sucked by the filter in the stock intake box, which should not be a problem anymore since the new filter is hooked directly to the intake. Right?
Is the money for a new turbo worth the extra 4psi boost? Is replacing the turbo the same as replacing the compressor wheel? And do I want a wicked wheel or is stock as good?
Right
Right
mklemin
03-04-2008 12:17 AM
closetredneck
05-23-2006 03:47 PM
ltfox
23
04-26-2004 10:58 AM
