98 F-150 5.4 - It runs rough and I can smell raw fuel out the exhaust. I scanned codes and I get this:
P3101 - can't find any info on this code.
P0009 - Engine position system Perf bank2
P0303 - cylinder #3 misfire
I would appreciate any help you guys can offer! Where do I start from here? We just spent $2k in January to have the passenger side head replaced because of a valve pulling into the head, I would like to try to tackle this problem myself and save some dough.
a 1/4 inch drive 7mm swivel socket snap on has a shallow one that works good if you dont have one you will have to remove the fuel rail and move it out of the way
3 back pass side you wont have to remove the fuel rail on that side just move the heater and pcv hoses also ck the hose clamps on the heater hose as thay are sometimes loose and allow coolant to leek on to the #3 cop and shorts it out
Thanks for the help and suggestions! I am going to tackle taking it apart this morning. If I can manage to get it apart, I'll be heading to town for the parts.
