Strange 1992 F150 5.0 Ignition Timing
Old 06-10-2006, 10:40 PM
captain kirk's Avatar
captain kirk
captain kirk is offline
I ran into a situation with a recently purchased 1992 F150 5.0 Liter that I haven't run into before with any vehicle. Perhaps you might share some wisdom in sorting out the problem.
I removed the stub bar and tried to time the engine with a light using cylinder number 1. When I checked the timing mark none was visible in the strobe. Confused by this I thought I must be loosing it so I tried hooking up to cylinder number 5 in the opposite bank and voila the timing mark appeared.
Now being as this is the first Ford vehicle I've owned am I missing something? Can't see the motor timing off cylinder number five.
Every manual I have says hook up to cyl 1. All the wiring is stock and the trauck is in showroom condition with 60000 miles. I am having a fuel consumption problem and that's why I'm checking the timing.
The next issue I had is the timing tab does not look like any tab I've seen before. It is a sort of cresent shaped tab with a hole at the bottom an approx 1/8 " notch in the middle and a pointer at the top with the word "Time " written on it. There is not a single degree reference mark or number on it. Sooooooooooo.... again to the manuals and no such timing tab is shown. So where does a person set the mark? Obviously not in the circle or perhaps the notch or the pointer for the 10 degree BTDC spec?
Old 06-10-2006, 10:43 PM
captain kirk
Additional info
I am refering to cylinder number 5 a being in the right hand bank as you face the vehicle. According to the manual cylinder number 1 is on the left as you face the truck according to the manuals I have. Or were they printed backwards?
Old 06-10-2006, 10:57 PM
ksdunlap's Avatar
ksdunlap
ksdunlap is offline
i think all referance is from the drivers seat
Old 06-10-2006, 11:04 PM
12secondstang's Avatar
12secondstang
12secondstang is offline
Cylinder #1 is the passenger side front. #5 is Driver side front.
Old 06-11-2006, 05:49 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome captin kirk, to Ford Truck Enthusiasts!
See you on the boards. ….
rlh68050
08-17-2019 06:19 PM
FordF100man
10-15-2015 11:29 PM
wolfman08
05-19-2009 04:05 AM
HENDEL
01-06-2008 09:23 AM
mlf72f250
09-13-2002 03:46 PM
Quick Reply: Strange 1992 F150 5.0 Ignition Timing
