Motorcraft ATF
Old 06-10-2006, 02:47 PM
80f100302's Avatar
80f100302
80f100302 is offline
Motorcraft ATF
Bought a case of motorcraft ATF from the stealership. It was multi-grade
mercon-v mercon and dexron III. I thought ford was against multi-grade,
and did not recommend it???????
I bought a case of 12, need at least 14. Can brands of ATF be mixed with no problem?
Also should I put in an additive?
Thanks for the help and advice!!!
Old 06-11-2006, 05:50 AM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
I get my Mercon V from my local Ford dealer too,at $3.00 a quart.Yes,you can mix other brands with Motorcraft.
I add a bottle of Red LubeGuard at each transmission flush.
F-WhiteThunder
1999 to 2016 Super Duty
02-21-2021 10:56 PM
folsomf250
07-03-2011 04:32 AM
aurgathor
Oil & Lubrication
01-16-2005 12:50 PM
Gypsy
02-29-2004 07:38 AM
Quick Reply: Motorcraft ATF
