Where is fuel system pressure relief valve?
Old 06-09-2006, 06:58 PM
bf5113's Avatar
bf5113
bf5113 is offline
Unhappy Where is fuel system pressure relief valve?
I want to relieve the fuel pressure on my '93 dual tank F-150 before disconnecting the two fuel lines from the back tank to replace it. The shop manual I have says the pressure relief valve is located in the "upper right hand side of the engine compartment". But it isn't! Does anyone know where the valve is and what it looks like so I can locate it and move forward with replacing the leaking rear fuel tank safely?
Old 06-09-2006, 07:08 PM
mike93's Avatar
mike93
mike93 is offline
It's the fuel pressure test port (schreder valve) located on the fuel rail up front and a little left of center ( driver's side) on the the engine. But a better way would be to either trip the fuel intertia cut off switch (above and a little left of brake pedal) or pull the fuel pump relay then crank the engine over for a few seconds. This is a common practice when changing the furl filter.
Mike
Old 06-09-2006, 09:02 PM
Cheggie's Avatar
Cheggie
Cheggie is offline
The fuel pressure relief valve looks sorta like a tire schrader valve, and it's on the fuel rail - the chrome plated hard line that the injectors are connected to. Sometimes they are tough to find, or get to. You can also remove the fuel pump fuse and crank the truck a few times to bleed off residual pressure. Or whack the inertia switch with the end of a screwdriver handle while the truck is running, that works too. Wrap a heavy cloth around the fitting as you take it apart. It helps to keep fuel out of your eyes! Hoo - you'll only ever do that once....don't ask me how I know.
Old 06-10-2006, 06:13 PM
magic-dot's Avatar
magic-dot
magic-dot is offline
..don't do it w/ a lit cigarette either... ..thank god that eyebrow grew back..........
ghost12
03-23-2015 05:58 PM
beckman
09-29-2012 08:36 PM
griz4718
1983 - 2012 Ranger & B-Series
06-12-2007 09:59 AM
u130747
12-09-2003 11:40 AM
Goodsath
12-09-2002 11:54 PM
Quick Reply: Where is fuel system pressure relief valve?
