I have a 2000 F-150 however, I cant find the low side, (Suction) charging connection. I found the high side but not low. Does anybody know where it is located? Is it on the accumlator and I just cant see it? Thanks....
potateo- you need to check the pressure on the high and low side when running, that tells you if you need more freon or not.-- too much dont help or make it colder.
