Rotating Tires
I always go same side front to back since a nasty incident waaaayy back with 2 grand worth of front tires.
Back then if you rotated side to side, you got bubbles in the tread from cord failures, and I haven't had the nerve to experiment since.
Tire manufacturers say they fixed that problem, so see what the MFG web site reccommends.
I agree with slc10844. The reason I do this particular rotation is the front tires will tend to feather on the outside edges. This is usually caused by the front tires only seeing braking. The rear tires see both acceleration and braking. Therefore, when you criss cross the front to the back, you will tend to level out the feathering to extend tread life. I move the even wear rears straight to the front. Even if the rear is not completely even, the tire is now backwards rotation than last time it was on the front, so it will still tend to level the wear.
Just my .02
Just my .02
SilverBullet131313
04-05-2010 05:00 PM
'04 4.0 XLT
1983 - 2012 Ranger & B-Series
02-15-2005 02:28 PM
