1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Spark Plugs- Motorcraft or Autolite
Old 05-23-2006, 09:05 PM
JTD1972's Avatar
JTD1972
JTD1972 is offline
I'm about to change my spark plugs and have a few questions. I know that the original Motorcraft plugs are no longer made (AWSF22E). The replacement plug according to Motorcraft is AGSF22WM which is a single platinum-iridium electrode (WM). And then there is the Autolite APP103 which is a double platinum plug. Does Motorcraft even make a double platinum plug for the 5.4 (PP)? Or should I use the Autolite APP103? Thanks
Old 05-24-2006, 07:23 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Look up the current and correct Motorcraft part number at www.motorcraft.com
The AutoLite PP is an excellent substiitute.
Steve
Old 05-24-2006, 02:44 PM
JTD1972's Avatar
JTD1972
JTD1972 is offline
The replacement plug according to Motorcraft is AGSF22WM which is a single platinum-iridium electrode (WM). Would this plug or the Autolite double platinum be better. Thanks
Old 05-25-2006, 07:19 AM
projectSHO89
You have your choice between the factory-recommended part and one made by the manufacturer of the OEM-specc'ed part.
Take your pick, either will do fine.
Ford has moved from the double plat design to a "fine-wire" design (plat/iridium) that does not require an enhanced side electrode, thus the WM design, for most replacement plugs.
Steve
Old 05-25-2006, 07:26 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
You could also spend $96 and get some Denso Iridiums.
Old 05-25-2006, 07:48 PM
JTD1972's Avatar
JTD1972
JTD1972 is offline
I have some information that may help some people out who are doing a spark plug change. I bought my spark plugs at Ford for $6.50 each and noticed on the box the part number SP479. It also had the part number AGSF22WM. Anyway, to make a long story short, Autozone carries these spark plugs but it's listed under the part # SP479 for $2.49. Autozone does not list it under the Motorcraft spark plug # of AGSF22WM, they use SP479.
So for anyone buying plugs at autozone SP479 = AGSF22WM
Old 05-25-2006, 08:54 PM
TDN's Avatar
TDN
TDN is offline
Same part that costs $6.50 at the stealership is only $2.49 at Autozone? Actually that sounds about right...
Old 05-27-2006, 12:53 AM
slenser's Avatar
slenser
slenser is offline
But do they work better?
Old 05-27-2006, 01:00 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
www.kragen.com also has them just copy and paste AGSF22WM into the search 2.59 each what a deal!
Old 05-27-2006, 02:28 PM
FTE Herman's Avatar
FTE Herman
Not that I can tell, just did it to appease the folks at Kenne Bell.
Old 06-03-2006, 04:30 AM
Ryyback's Avatar
Ryyback
Ryyback is offline
Staying in the same field here, I have some info on spark plugs etc. I changed mine out recently to Autolite, and I did the Spark plug wires as well. And when I got done, it wouldn't start!! Problem--FIRING ORDER--we messed up on 2 wires-D'OH. Check the firing order on your trucks if you ever have the same problem.
keydr
1983 - 2012 Ranger & B-Series
06-08-2010 10:00 AM
Larry S
23
07-20-2008 01:08 PM
Vegas Ernie
02-17-2008 09:02 AM
PeteC
1999 to 2016 Super Duty
17
12-17-2007 02:04 PM
pcguy760
03-27-2007 05:45 PM
Quick Reply: Spark Plugs- Motorcraft or Autolite
