Hard start
Old 05-16-2006, 10:07 AM
oldblue31's Avatar
oldblue31
oldblue31 is offline
Hard start
For some reason lately when I try to start my truck It just keeps turning over and acts like the batteries are draining down. I just put 2 brand new ones in yesterday. While doing this you can see the unburnt fuel smoke coming out the tailpipe. I noticed today that if I leave the key switched to on and wait at least another 30 seconds after the wait to start light goes off before cranking then it turns over and starts fine. Once started it always cranks right up, but if allowed to sit for 8 hrs or so its right back to the same thing.It seems like it may have something to do with the glow plugs . I'm in southest Ga. and it's not cold in the least bit. Thanks.
Old 05-16-2006, 11:28 AM
1997F-350's Avatar
1997F-350
1997F-350 is offline
the little cold it is it will still be hard.
take a look at your volt meter when you turn on the key. if it doesnt drop almost to the 8 your gpr is bad.
you can get a new one from napa for 20 bucks. gpr 109
or a heavy duty stancor online. 40 bucks.
Old 05-16-2006, 12:19 PM
oldblue31's Avatar
oldblue31
Is it normal to have to wait a while after the wait to start light goes off before it will crank?
Old 05-16-2006, 01:43 PM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
If you are having to wait after the light goes off, no colder than it is here, then it sounds like some of your glow plugs are not working. Also have the amp draw on your starter checked, if your starter is dragging and not spinning up fast enough it will make it hard to start. Good Luck.
Old 05-16-2006, 07:55 PM
powerstroked162's Avatar
powerstroked162
powerstroked162 is offline
Make sure you got some fuel in the fuel bowl. Some times the fuel bowls can get gummy and not crank over right away. Mine did that shiznit to me today. i WAS CHECKIN EVERYTHING. then for some reason i checked the fuel bowl and there was sledge built up on the inlet holes into the fuel regulator. Washed it out and filled it up, fired right up! good luck
Cjambla
11-29-2012 08:55 AM
DieselRugger
17
10-05-2012 04:19 PM
H2oRodeo
03-01-2008 12:35 AM
W.O.T.PIMP
16
09-06-2006 11:58 AM
fleabag99
07-19-2006 12:45 PM
Quick Reply: Hard start
