Missing 2nd fuel tank and switch
I just recently purchased my first Ford truck. It's a 78 F-250 133" wb with a 400, C6, NP205, dana 44 front, and dana 60 rear. My question is, how can I tell if this truck originally had duel tanks? The bed has two fill doors with the front fill going to neverland, but inside the cab I can't seem to find any change-over switch. I'm curious if the bed has been changed or if the switch is just missing. I'd like to put the second tank back in if I could, but I don't want it to be more hassle then it's worth. Thanks for any help on this as the forums have already been a wealth of knowledge ( I just finished setting my headlights up on relay's this morning).
on
Check the fuse panel. Is there a fuse and wires in the aux-fuel section of the panel. If not then it's safe to say it's the bed that's been switched out.
To add the second tank, you would need the wiring for the second tank, a tank with sending unit, a way to bolt the tank to the truck, brush guards if applicable, filler neck, a heater controller with the tank selector switch, a wiring diagram, the valve on the framerail, fuel hose, and the metal lines that go to the charcoal canister from the tank.
I would have a parts truck with dual tanks or a way of getting parts from a truck that has dual tanks, and have all the parts put aside before begining.
It's possible and would just require bolting things on, and some moderate skilled wiring in the fuse panel if the truck never had the aux tank.
hope this helps
hope this helps
The 78's didn;t have a cab tank and no switch on the floor.
The fuel selector for DUAL (2) Tanks is beside the heater switch.
If the switch isn't there Other than sending away to Ford for the build sheet, it will take some detective work to see iof it came with Dual tanks.
Like see if there is a tank supply valve just in front of the rear tank .
Anonym
26
07-05-2020 01:30 PM
lemonshindig
22
01-30-2016 09:26 AM
SteelSteeds
08-16-2015 07:03 AM
