Door Panel
Cake Walk
All that you have to do is there is two plastic pieces on top of the pannel one is triangal by the mirror and the other is at the back of the door. those just pull off then you have to take off the door handel its under the round piece its like an 8 mm then just slide the pannel up and its off
havent seen a 98 but i think its a bit similar.....behind door handle there is a screw so you gotta snap cover out first.....on top of door left hand side if drivers.....snap out piece and another screw there....push up the handle and your good. Carefull because pins are holding down. hope this helps pal because i got a 99
