Sponsored by: Auxito
insuffient flow at cat
Old May 4, 2006 | 09:29 AM
yasky69's Avatar
yasky69
My Ford F150 is throwing a code again. This time its says I have insuffient flow at the cat. Is it time to replace the cat?
Old May 4, 2006 | 12:35 PM
wezol5484's Avatar
wezol5484
Probably not your cats. How long has (if at all) it been since your EGR valve has been replaced? Check the vacuum hose on the EGR valve for either a leak or if its come off.
Old May 4, 2006 | 03:34 PM
projectSHO89's Avatar
projectSHO89
There is no such thing as a code for "insuffient flow at the cat."
Either you have a P0401 - Insuffient EGR flow or a P0420/P0430 catalyst below efficiency.
Whichver it is, click on SEARCH, enter the correct code you're getting as your SEARCH keyword.
Both have been well covered in the past. A little digging will show what's going on and how to fix it.
FWIW, EGR valves seldom go bad. Most that are replaced don't fix the problem they were intended to address.
Steve
Old May 4, 2006 | 07:45 PM
yasky69's Avatar
yasky69
sorry, the code is a Po430. When I started the threaded I couldn't remember the code number.
EGR was replaced a month ago, along with the tube that goes down to the manifold. Vacuum hoses have been checked for leaks, and the holes that go from the TB to EGR were cleaned 3 weeks ago. The truck has 218000 miles on it. It is also referring to bank two, so I am assuming that would be the passengers side
