Really Dumb Question
Old 04-16-2006, 10:58 PM
zman764's Avatar
zman764
zman764 is offline
What exactly is a flathead engine? Believe it or not I am mechanically inclined and understand how an engine works and alot about them.
Old 04-17-2006, 12:29 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
Good question not a dumb one, go to the Flathead Engine sites at the links below. If you know how the overhead engine is built with the valves in the head you will notice in the Flathead engine drawings in the links below how they are in the block on that design.
http://www.vanpeltsales.com/FH_web/flathead_home.htm
http://www.vanpeltsales.com/FH_web/f...itelinkspg.htm
http://www.btc-bci.com/~billben/flathead.htm
Hope this helps
Rod 51F1
Old 04-17-2006, 12:30 AM
mtflat's Avatar
mtflat
mtflat is offline
They weren't really called flatheads until the OHV engine became common in the 50's. Then the term popped up and the rest is history. There are no dumb questions.
The valves are in the block beside the pistons. The head is only a waterjacket with sparkplugs and compression chambers. And I guess technically the heads also serve as valve covers of sorts.
Check out this website - it covers a good bit.
edit: evening Rod, I see you've got it covered! - Tim
dadstruck
02-20-2016 10:22 PM
jowilker
11-10-2012 10:43 AM
05-03-2002 01:31 AM
Flash
1997 - 2003 F150
03-24-2002 10:12 PM
RRL78
1978 - 1996 Big Bronco
10-17-2000 12:10 PM
Quick Reply: Really Dumb Question
