Really Dumb Question
Old Apr 16, 2006 | 10:58 PM
zman764's Avatar
zman764
What exactly is a flathead engine? Believe it or not I am mechanically inclined and understand how an engine works and alot about them.
Old Apr 17, 2006 | 12:29 AM
51ford fan's Avatar
51ford fan
Good question not a dumb one, go to the Flathead Engine sites at the links below. If you know how the overhead engine is built with the valves in the head you will notice in the Flathead engine drawings in the links below how they are in the block on that design.
http://www.vanpeltsales.com/FH_web/flathead_home.htm
http://www.vanpeltsales.com/FH_web/f...itelinkspg.htm
http://www.btc-bci.com/~billben/flathead.htm
Hope this helps
Rod 51F1
Old Apr 17, 2006 | 12:30 AM
mtflat's Avatar
mtflat
They weren't really called flatheads until the OHV engine became common in the 50's. Then the term popped up and the rest is history. There are no dumb questions.
The valves are in the block beside the pistons. The head is only a waterjacket with sparkplugs and compression chambers. And I guess technically the heads also serve as valve covers of sorts.
Check out this website - it covers a good bit.
edit: evening Rod, I see you've got it covered! - Tim
dadstruck
16
Feb 23, 2025 06:53 AM
jowilker
Nov 10, 2012 10:43 AM
May 3, 2002 01:31 AM
Flash
1997 - 2003 F150
Mar 24, 2002 10:12 PM
RRL78
1978 - 1996 Big Bronco
Oct 17, 2000 12:10 PM
