brake rotor groove
Couldn't the groove be caused by rocks or dirt getting between the pad and the rotor? I guess it doesn't even need to be a rock just plain dirt would do it. I know on our chevy work trucks everytime we take them out on gravel roads they end up squeeling do to the dirt. I wouldn't think the dealer would warrenty that.
Originally Posted by superrangerman2002
I thought that brakes were not a warranty item as they fall under normal wear and tear just like air filters.
I've never seen a Ford dealer warranty any type of brake work on a vehicle with more than 5000 miles.
In my case, the rotors got grooves on both sides, and warped just a little as well. The dealer asked no questions and handled the issue better than I might have expected.
Only problem is I now have front rotors that have been turned once, rather than new rotors. But, I did get new pads and calipers.
As a side note, the brakes prior to the work just never seemed to feel 100% "firm". Sometimes felt like there might have been a little air in the lines.
After the work was done, that problem is gone.
Originally Posted by BrianA
In the cases cited, the issue was outside "normal wear and tear". There was a known issue with rotors up thru some build date (in Dec '04) that would get you free rotors if you had problems.
is there anything written about that build day prior to dec 04?
https://www.ford-trucks.com/forums/s...d.php?t=461110
And I do think there is mroe info in the Brakes forum. You'd just have to search it and see.
I seem to remember the service manager mentioning that my rotors had a green dot on them indicating I had the new style rotors.
See this thread:
