clutch adjustment
clutch adjustment
I have a '89 F150, 300 straight 6, with a 5 speed manual.
It's getting harder and harder to shift. I'm getting more 'slop' in the clutch pedal. I've crawled around and can find no way to make any adjustments. On my older truck I could extend the push rod, but this has a cable/hose that goes directly into the tranny case. Any ideas?
There is no adjustment on that clutch. If you still get a lousy pedal, the slave may be leaking. I would try bleeding it first, and if that doesn't cure it, you are probably looking at a new clutch. It's been my experience that when a M5OD gets hard to shift, it's an early warning sign that you need a new clutch.
There are several plastic bushings in the pedal assembly under the dash. I would check to make sure that all of those bushings are not worn to the point of allowing slop in the clutch pedal cross shaft. You can buy a new cross shaft lever from Ford to adjust the clutch, but the hydraulic system should be able to adjust for clutch wear.
Clutch Problems
I have an 89 F150. 302W with 5 spd manual and it does the exact same thing. Am about to install a new clutch and the internal slave cylinder cause thats leaking slowly as well. Try the old test: high revs in 4th gear at about 10 - 20 mile an hour. Let the clutch out and see if it slips. If so then I reckon the cog box will have to come out cause the clutch is shagged !
tpolley
03-10-2015 02:39 AM
qquake2k
01-12-2015 05:30 PM
buckeye_nc
15
09-20-2009 02:32 PM
