'68 302 alternator/ignition wiring
Old 04-02-2006, 07:53 PM
debestuss's Avatar
debestuss
debestuss is offline
I need some help. We are ready to start this thing but can't get any fire from the ignition/key but I can jump the solenoid and turn the engine over. I don't know where the wires go. I've figured out which wires are the headlights but other than that, I don't know. What wire goes to the coil? I'm running points for now. My biggest problem is the alternator and solenoid wiring. Can anyone help?
Old 04-03-2006, 07:46 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
See if you have a red/lightblue stripe wire going to the keyswitch. Ford used this for many years for the start wire. This wire should leave the keyswitch and go to the neutral safety switch either on the clutch pedal or the side of the auto tranny. From the neutral safety switch it goes right up to the starter solenoid/relay. It stays the same red/lightblue color at the starter solenoid.
Your alternator wiring should look like this if you have a alt light in the dash. The colors may be different though.
If you have a factory ammeter in the dash, your wiring will look like this, but the wire colors may be different.
Old 04-03-2006, 08:14 AM
subford's Avatar
subford
subford is offline
Here is a close up of the Charge Start circuit.
Old 04-03-2006, 08:19 AM
subford's Avatar
subford
subford is offline
Here is an over all view. For better view email me with your email address and tell me what diagram you want. Do NOT PM me, as the email address will not go through.
Old 04-05-2006, 04:53 PM
debestuss's Avatar
debestuss
Thanks guys. I'm getting closer but you it gets difficult when somebody cuts the wires at the firewall and does alot of splicing. I have to unf...k this wiring mess.
patclem
08-21-2015 09:39 PM
MeatRo
Electrical Systems/Wiring
04-25-2015 11:19 AM
sony420
01-16-2015 11:50 PM
sdetweil
06-13-2008 09:10 PM
ford390gashog
11-25-2004 11:31 PM
Quick Reply: '68 302 alternator/ignition wiring
