Where are the fusible links for the glow plugs?
Old 05-01-2007, 12:37 PM
just another truck's Avatar
just another truck
just another truck is offline
The thread is glow plug ohm test
Old 05-01-2007, 01:31 PM
WuShock's Avatar
WuShock
WuShock is offline
Originally Posted by just another truck
I am guessing that you are going to need to do a resistance check from ground to the different Glow plugs, but I am thinking that your problem is going to be the valvecover gasket, am I wrong here, that is the only harness I can think of???? If you can look in this thread for glow plug wiring, someone posted it about a week ago I think..
The "UVC" or Under Valve Cover harness fail more than a CPS on our trucks. If these fail you will/should receive a code for each and every glow plug on that bank of the engine (either all even codes or all odd numbered codes depending on which side of engine). If I was going through the trouble of pulling the valve covers I would replace the harness with new clips from Ford. The harness is about $25-$30 from ford (x2, 1 for each side) might as well replace glow plugs while your there.
bigreentruck
01-19-2017 12:03 AM
pyroracing85
1983 - 2012 Ranger & B-Series
10-14-2016 06:48 PM
Coastal Kenny
New Member Introductions
07-09-2016 12:14 AM
remhaust
6.7L Power Stroke Diesel
07-01-2015 11:29 AM
papadelogan
Electrical Systems/Wiring
01-03-2008 04:52 PM
Quick Reply: Where are the fusible links for the glow plugs?
