1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trailer Parking Light Relay Location
Old 03-08-2006, 07:57 PM
teg2_nv's Avatar
teg2_nv
teg2_nv is offline
Does anyone know where the trailer parking light relay is on a 2000 F350 Diesel? Both the reverse and parking lights are not working at my trailer connector. The only reference is to the instrument panel and it is not under the dash or in the power distibution block under the hood. I have found the reverse relay under the hood but cannot find the parking relay.
Old 03-08-2006, 08:25 PM
fomocofan's Avatar
fomocofan
fomocofan is offline
The trailer marker lights are on a fuse. I don't remember the fuse location, but look in the manual, it should be a 20 amp mini fuse.
Old 03-09-2006, 12:13 AM
skinner00's Avatar
skinner00
skinner00 is offline
if the reverse lights dont work from the connector i would check to see if you even have a trailer reverse light relay from the factory, mine didnt. they are in the small relay boxes next to the main fuse box under the hood. it should be the set closest to the firewall
Old 03-15-2006, 10:09 PM
teg2_nv's Avatar
teg2_nv
teg2_nv is offline
All relays are in under the hood (reverse, etc). I believe it is somewhere in the instrument panel, can't find it in the manual, under the hood or in the fuse panel under the dash
Old 03-15-2006, 10:14 PM
fomocofan's Avatar
fomocofan
Not trying to be rude or anything, but did you check the trailer park light fuse in the fuse block?
It may not be your problem, but that is usually what blows first when the lights go out!
Old 03-15-2006, 10:27 PM
teg2_nv's Avatar
teg2_nv
teg2_nv is offline
Checked all the fuses. All good. I have had this problem since I bought the truck about a year ago and tapped a wire from the rear clearance lights for the time being. I bought a bigger trailer with a lot of parking lights and don't want them on the same circuit anymore. (possible overload)
Old 03-15-2006, 10:36 PM
fomocofan's Avatar
fomocofan
Oh Ok...Well that trailer light relay Doesn't come installed from the factory..It is usually dealer installed when the brake controller is installed..
I would see if the relay is even in there..and it will be under the hood..I belive there is a relay box next to the Master cyl.. It holds two relays I think...one may be missing.
If so, any trailer dealer or Ford dealer can hook you up..or look at it for ya..
Old 03-16-2006, 09:05 AM
HarryD001's Avatar
HarryD001
HarryD001 is offline
Yes look to the fuse box on the fender well next to the master cylinder as fomocofan stated
Old 03-16-2006, 10:20 AM
SCHRADE's Avatar
SCHRADE
SCHRADE is offline
Here are the relay's part number
FOAB-14B192-AA both relays same
ScottInTexas
2004 - 2008 F150
05-21-2018 01:00 PM
docergo
05-06-2018 09:15 AM
ceerebus
07-12-2017 09:02 AM
jed1894
17
03-27-2016 11:41 AM
77f2504by4
10-23-2015 09:35 PM
Quick Reply: Trailer Parking Light Relay Location
