Front end bounce on 2004 F250, anyone?
I have an 04 F250 6.0 CC 4wd. When traveling at 40 to 43 mph, it has an annoying front end bounce that will spill coffee if I don't either accelerate or slow down. It had the bounce when new on stock wheels and tires. I have since installed a Donahoe Racing leveling kit, 2" blocks in the rear, bilstein shocks and 33" Terra Grappler tires. It is getting worse. I've had the lift and tires for about 13K miles now and recently rotated the tires, which also made the bounce a little more noticeable. Does anyone else have this problem or maybe has found a fix for the problem? Oh yeah, it won't bounce if I have something heavy in the bed.
Yeah, I checked the death wobble thread, that's not it. The steering wheel doesn't shake side to side, the whole front end bounces straight up and down. You can even look at the edge of the hood and see it bouncing, or if you have a lady in the passenger seat, you can see bouncing as well.
I saw a thread on this about a year ago from someone with an 04, but I didn't pay attention to see who it was nor do I know if he ever found a cure, but I do know he was looking for a solution and it is exactly the same as he described it.
I have an 03 PSD, extended cab, long bed, 4x4 - completely stock. My front end bounces in the 38-42 mph range. Very annoying - happens on acceleration and deacceleration. I don't recall this happening until I put on 33" tires a couple of months ago. I was thinking it was probably a wheel/tire balance problem, but I'm no expert.
have you check the struts and shocks, and other front end stuff? I have a suburban that the front end bounces really bad. but that is due to the shocks. and the reason it has probably gotten worse with the bigger tires is because the wieght of the front end is displacing the air in the tire causeing it to bounce worse, have the same problem with the suburban also. you may need to beef up the suspenion on the truck. and it doesn't do it with a load is cause you are putting more wieght over the rear axle, which is causing the truck to lean more to the rear, even if you don't notice the rear squatting. but that is just my experiance with that problem.
I feel honored that this thread has been resurrected. I have not found a cure since my original post. I did replace my tires with bfg a/t's and also my rotors. No change. Oh yeah... Put some new wheels on also. The very first thread I ever read about this, the guy said he was relentless with his dealership and apparently they also really wanted to fix the problem. The regional Ford rep came out and somehow they figured out if they hung a cylindrical steel counterweight off of a cantilevered arm attached to the frame somewhere near the fuel tank if I remember correctly, they were able to eliminate the bouncing. I have tried to since find info on this and have never been successful. So now I never drive at that speed because it drives me nuts.
This problem is nothing like death wobble. I think there are several causes for death wobble, but death wobble is when the steering wheel shakes back and forth violently and with such force that you cannot stop it with your hands. The only way to regain control is to slow down or possibly speed up. But it always feels safer to slow down. Think tank-slapper on a motorcycle.
Again, this problem is absolutely not death wobble. Carry on.
But anyway they are not the same thing. The bounce is another phoenomena that occurs with these trucks that has a lot to do with frame resonance and is typically more prevalent on the longer bed trucks. Confirm that your tires are at the recomended pressure for the tire load. Adding bed weight will also minimize it. Some say trucks with trailer hitches (which is pretty much all of them) and or rear sway bars are minimized.
I have had it since new as well as with all the mods i have done. I just live with it.
Im no expert...but i would think add a leaf would help
Milwaukee1979F150
1999 to 2016 Super Duty
12-01-2009 09:30 PM
