97 diesel computer removal
i've got a 97 powerstroke with 5 speed trans. i've got to take the chip out(hypermax) and clean the terminals to diagnose a problem i have..anyways; i heard i need to remove the 40 pin connector throught the engine compartment from the firewall. then come in through the inner left wheel well and remove the top and bottom nuts that hold the computer in the firewall....and then slide the computer out from the wheel well...is this right?...any other way i can get to the computer or chip!?
chip removal
If you need to clean the connections, yes you need to remove the emergency brake assy. and take the wheel well cover halfway off to get at the pcm. jcab
pcm removal
The emergency break is in the way of access for the chip for removal. And the pcm will be removed from the engine compartment, after the wheel well cover is removed. jcab
why will i remove the emergency brake assembly?>...and will teh ecm itself come out from the cab or engine compartment?
yes!!
IF YOU WANT TO CLEAN THE CONNECTIONS, YOU HAVE TO REMOVE THE PCM, IF YOU JUST WANT TO PUT CHIP BACK ON, YOU WON'T HAVE TO.
OHHHok....i undertnad now---anyways today i removed the computer and chip----BAD idea....that thing wont even rev up w/o that chip...anyways---if i just removed the parking brake assembly..would i have access to the chip w/o having to remove the computer again?
Dirt-Road-Kid97
16
08-09-2017 06:52 AM
Xcelor8
02-28-2016 05:31 PM
airboatoutlaw
1978 - 1996 Big Bronco
03-05-2011 05:22 PM
