can you use diesel fuel in an electric gasoline fuel pump?
Old 02-07-2006, 10:16 PM
thesprocket26's Avatar
thesprocket26
thesprocket26 is offline
I don't know if it would corrode the innards of a gasoline fuel pump if you ran diesel through it. It would be an easy fix for my friend if you could. Thanks for any info.
Matt
Old 02-07-2006, 10:33 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Not really sure- it shouldn't affect anything in there, but you never know. If he has an electric pump laying around, give it a try.
Old 02-09-2006, 07:04 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,163 Likes on 2,207 Posts
yes you can do it. there will be no major problem other than a reduced flow due to the diesel fuel being a bit heavier than gas. on the inbed fuel transfer tank pumps, gas will pump at 15-16 gallons per minute, and diesel will pump at 10-12 gpm.
Old 02-09-2006, 08:11 PM
The SnoMan's Avatar
The SnoMan
The SnoMan is offline
I agree, no problems other than a reduced flow rate.
Old 02-09-2006, 10:17 PM
thesprocket26
Thanks all for your help. You all ROCK!
DarrellinCeres
1999 to 2016 Super Duty
16
10-14-2016 03:53 PM
Patrick R.
General Automotive Discussion
20
03-07-2016 11:40 PM
bryanw47
09-28-2015 07:26 PM
Ian123
General Diesel Discussion
06-15-2011 08:31 AM
dieselcontam
17
06-09-2011 01:41 AM
Quick Reply: can you use diesel fuel in an electric gasoline fuel pump?
