Current generation 2.3l oil capacity?
I usually put in about half a quart below what the manual says, start it up and let it run for a minute or so, then top it off until its about 3/4 of the way into the "safe" area.
Too much oil can be just as bad as not having enough. The crankshaft can whip it up into a foam, and the oil pump has a hard time pumping foamed oil. Not to mention it robs you a couple of horsepower and some fuel economy.
BB
11-27-2000 06:22 PM
