02 Ranger speed sensor
I am trying to install a truespeed speed calibrator and a cruise control in my 2002 2wd, 2.3 16V ranger. The intructions in both kits list a gray with black stripe wire coming from the speed sensor. But when I look at my (7.5") differential housing connection, the two wires are colored solid hot pink and pastel green with a black stripe. The wires lead to a harness loom within 2 feet and the entire rear loom ends at a multi pin connector outside the chassis underneath the driver seat. There are three total solid pink wires going to the pin connector but only one pastel green with black stripe. The wire I'm looking for by the intructions is a light gray with black stripe wire. There is none going into the multi pin connector. My question is, do the wire colors change on the other side of that multi pin connector? If not, which wire is my target wire? My guess is the pastel green with black stripe wire. Any help would be well appreciated. Thanks
Nope, the more things I do to this truck the more it wants to fight me. The wire colors remain the same to the ABS module. Hot pink and green/black. I'm sure the green/black wire is my target wire. What led up to all this is that I just installed a cold air intake, jet chip and opened up the exhaust. 4.56 gears, new cross shafts and a posi. Fab tech 2.5" performance susspension with 15-32X11.50 tires and way over done bushwhacker extend-a-flares (makes it look like an ATV). The susspension, flares and tires fit very well. The gears however were a different story The truck is a dog with out the Jet chip, but with the chip overall performance and gas milage is the same with the new tires and gears as it was when it was stock. These 16V 4 bangers are pretty zippy stock. I'm sure leaving everything stock with just the intake, chip and exhaust done would make it a little terror on the interstate. A 4.10 gear set and the engine preformance stuff with a good set of tires on stock rims would be a fun choice for this truck. All the heavy tires and gears plus the added wind resistance bring it back into perspective. The ring on the new gear set is twice a thick as the old ones (size 12 into a size 8 shoe kind of thing). It could still use a colder thermostat and open the ehaust some more. After that it's new cams. But for now there isn't even a thermostat option for this motor yet. It's been confusing from the start with this truck because no one has worked on this motor much yet. Thanks for the help, it made everything obvious for me.
Rockledge is right. Pin 68 off the PCM is a gray/black wire. But both instruction manuals for the speedometer calibrator and the cruise control talk about a gray black wire off the ABS module and the speed sensor. Also the speedometer calibrator instuction says the gray/black wire can be located at the "GEM module connection C201B pin 14" in which there is no gray black wire. However when I look at the two wires coming off the ABS module and the two wires off the speed sensor, they are pink (tach?) and green/black (VSS?). I still think it's the green/black wire because the speed control and speedometer calibrator instuctions talk about the speed sensor and ABS connection points being best, but they both say gray/black wire should be where the green/black wire is. Neither of them talk about pin 68 off the PCM. Any kind of comment or advice is still appreciated on this one since I am no expert. Thanks again
The wiring diagram for the '02 does indeed show a GY/BK wire coming off the GEM at Pin 14 regarding vheicle speed control. Are you sure about the component you are looking at (behind the center dash) and/or the colors of the wires?
There is no indication in the diagrams that there is a GY/BK wire coming off the rear diff speed sensor nor the ABS module.
What is the GEM? I know the PCM is right center at the top of the fire wall inside the engine compartment. That is where I installed the JET power chip. On that component, pin 68 is a gray/black wire. The only wires coming off the differential are a pink wire and a green/black wire which is the same as the two wires going to the ABS module which is on the driver side fender well straight above the shock tower. I guess I don't know what the GEM is. I assumed it was underneath the driver seat. Is that not right? Thanks for working with me on this.
I also have a 2002 ranger, and i added cruise control. I bought a factory unit off ebay and installed it myself.
Pull the stereo out and the gem module is located off to the left in in the hole where the stereo came out of. Tap into the grey wire with a black stripe (this is the speed sensor wire that the computer uses). Theres about billion wires there but it should be the plug that comes up into the bottom of the module. I guarantee you that is the right wire because i used it for my cruise control and it worked perfect without any problems, besides the fact that i had to modify the 4 cyl throttle pull cable to work on the 3.0 linkage.
There you have it from someone who's been there & done that!!!!
GEM = Generic Electronics Module, with a name like that we can imagine that many things feed into & out of this beast!!!!
It is indeed located behind the radio, which must be pulled to get to it.
You can make loan of, or buy the tool to do this at most autoparts stores.
Be sure you pull the battery negative cable first & wait 15 min or so, before you fool around with the wiring.
Also be sure to ground yourself good, to bleed off any static charge you or your tools pick up, so you don't ZAP something in the GEM or it's related connected circuits.
Let us know how it goes.
The GEM and PCM work together on many things and share several sensor signal inputs, including the VSS.
Wildpony2000
1983 - 2012 Ranger & B-Series
01-27-2013 10:11 AM
cgi2099
10-05-2011 07:12 PM
jle70
05-16-2007 11:02 AM
