EGR problem
Old Jan 1, 2006 | 12:21 PM
1REDWS6's Avatar
1REDWS6
EGR problem
How about this. New guy, and 2 questions already.
I am working on a '00 Mazda B2500, 2.5 5 speed with about 65K miles on it. The SES light was on. I pulled the codes and got 2 codes. One was a P0401, the other a P0402. These are both EGR related codes. One is for excessive flow of the EGR, the other is a restricted flow for the EGR. How does one acheive restricted and excessive flow at the same time?
I did pull the EGR, and the tube and checked to make sure they weren't clogged up. I know Ford's are notorious for this. Both looked good, and the EGR did not appear to be sticking.
What should I check?
Old Jan 1, 2006 | 12:59 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
I'd be thinking a bad DPFE sensor first, then possibly a bad EVR.
Reference: The Ford DPFE/EGR System
Old Jan 1, 2006 | 01:27 PM
1REDWS6's Avatar
1REDWS6
Thanks for the info, including the diagram. Is there a way to test these items, or is it just plug and play and see what happens?
Old Jan 1, 2006 | 02:06 PM
g_k50's Avatar
g_k50
Check the warrenty. Emissions is covered for 50,000 miles. I had the same code and Ford fixed it for free I did spend 500 on the brake job thou.
