1998 ford explorer 4.0 blown fuel pump fuse
Originally Posted by 87 XLT
Heres how a 97 is wired, yours is probably the same: PDB fuse 3 to relay to inertia switch to fuel pump. Try opening the inertia switch & see if a new fuse blows.
I opened the inertia switch and put a new fuse in, then turned the key on. The fuse did not blow. I then closed the inertia switch and then turned the key on and the fuze immediately blew. I am assuming now that there is some kind of wiring problem after the inertia switch, or the fuel pump itself.
I do not have a manual for the Expy, does anyone have a wiring diagram for the fuel electronics?
Thanks,
Darren
The 97 EVTM shows from inertia switch to fuel pump is wired pink/black stripe.
Theres a connector that appears from the diagram to be under the drivers side floorboard.
If you open that connector & a new fuse does'nt blow, theres a short in the PK/BK between there & the pump or possibly the pump is locked up.
Have you tried giving the gas tank a good whack with your hand? Sometimes that will bring a bad pump back to life temporarily.
Is that connector under the dash or under the floorboard? The wiring diagram isnt clear on that. If it's under the dash, take a look at the wiring where it goes thru the sheet metal to the underside of the truck.
Also there is a connector at the tank with 6 wires that you can disconnect & see what it does.
Brenda Lamka
20
12-16-2016 04:18 PM
mweaver644
01-25-2014 11:20 PM
hurley1718
04-26-2011 11:21 PM
myblkexpy
02-06-2011 09:02 AM
