mid 90's explorer speaker removal
i purchased new pioneer speakers, and i need to install them. what do i have to take off to access the speakers? does the whole inner pannel need to be removed? all help appreciated.
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/showthread.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards.
To do so start off taking off the 2 screws near the door handle, then around the actual door handle there is a small cover (going around it if you look at the handle you will see the outline) take a small flat head and from the right side of the panel push it left (towards the front seat) it will pup off now the rest of the panel is push locks so take a small screwdriver to the bottom of the panel (where you cant see it) and pry it out once you get the first on out you can pry the rest with your hand after you get all the push locks undone pull the door up (towards the window) and your done speakers is held in by 4 small bolts and just do the reverse to put it back
