F-250 2wd Lift kit?
I have an 81 F100 4x4 LWB which has had a 3inch lift front and rear.
It comprises of blocks under the rear springs, dropped radius arm brackets and longer springs and shockies. You will also need to install adjustable ball joints to the top of the spindle assembly to cater for the height increase, other wise you have a front end like a VW. I have also fiitted a steering damper.
You should be able to purchase a kit in US as mine came from there imported into OZ, supplied and fitted, $AU3600.
Hey check out http://www.rockymountainsusp.com/fd2_f2_350.htm they have a lift kit but nothing for 460 if i read it right. I dont know anything about them.
boatman41
04-14-2011 02:37 PM
