4.6 engine swap
4.6 engine swap
My engine blew in my 00 F-150 looking to get a new engine wanted to know what my options are. Looking for more power and have about a 5000 budget.
Looked into rebuilding my current motor and getting it ported and polished new cam and injectors but don't know what to expect performance wise. Need Help
Why not try going to the 5.4. Then you could port and polish that for even more hp.
Should pretty much drop in with a change to the puter. (Puter from a 5.4) That is if you are doing the entire engine. I am not sure but I don't think the fuel rail is the same.
If you are going to stick with the 4.6, have the shop that builds it bore out the cylinders and install a stepped up cam. Then you can do the air intake mods and exhaust mods. Should give you quite a change in performance.
When I had my Bronco, I replaced the motor and went from a 302 to a 351 bored 30 over with performance cam. I did a long block swap with a few other parts and it cost me a total of $4000. You may be able to call them and see who they work with cause the warranty was nationwide when I got mine done. They may have someone close to you.
Quality Engines & Transmissions LLC
7939 E Arapahoe Rd
Englewood, CO 80112 - 6275
(303) 290-7700
7939 E Arapahoe Rd
(303) 290-7700
wadar1969
10-17-2010 04:11 AM
cte4000
12-22-2009 08:44 AM
1978f150sc351m
01-15-2007 02:49 AM
