Steering Column Bushings?
Old 12-05-2005, 01:48 PM
Ford100_9's Avatar
Ford100_9
Ford100_9 is offline
Hello:
I was wondering where i could find steering column bushings for my 1965 f100 3 speed on the column.
Old 12-05-2005, 02:07 PM
banjopicker66's Avatar
banjopicker66
banjopicker66 is offline
Several of the vendors who advertise here sell them. They were identical for a number of years, at least to '79 and possibly later.
Old 12-05-2005, 08:02 PM
barry's Avatar
barry
barry is offline
They are C3DZ 3517-A (bearing)and B1AZ 3518-A(bushing). Top and bottom are the same. Check with your local dealer and see if they have them. I haven't looked in a while to see if they're still available or have gone obsolete.
Barry
Old 12-05-2005, 08:21 PM
Customcab's Avatar
Customcab
Customcab is offline
Hey Barry what's the difference between Steering column bushing and the coupler? I see a display for the upper column bearing & also a column sleeve are these the same as refering to bushing?
Mitch
Old 12-06-2005, 08:53 AM
daggerNC's Avatar
daggerNC
daggerNC is offline
Better check/verify first. I just disassembled a '73 steering column and my '66 column for a PS setup. They both have the identical plastic cone shaped bushing that rides on the steering shaft at the bottom, but the top bushing is not plastic, it is a metal cone. The bearings I did not remove/replace and just repacked them with my fingers. Note that at the bottom of the shaft where the stop is secured to the shaft there is a felt like seal that many columns are now missing (my '66 was torn but luckily my '73 was in good shape). I believe bushing and sleeve are the same thing. The bearing is a metal bearing assembly that is NOT the same thing as sleeve/bushing.
SeaCarr
02-10-2015 10:51 PM
Reef Tech
10-03-2014 12:20 PM
Macs1964F100
02-02-2014 09:14 AM
rwrogers
01-29-2014 06:58 PM
DW SD
10-16-2013 05:55 PM
Quick Reply: Steering Column Bushings?
