89 460 FI Timing Chain
Will early pre 87 timing chains fit an 89 460 cu in fuel injection motor.
If I want to replace the stock chain with a heavy duty double roller chain, what should I use? I can't find a high performance application for an 460 FI motor.
I believe that FI engines do not use the 8 degree retard chains, so will an early "straight up" chain work?
I know that the large truck 370/429 chains are double roller. They are the same cam and block but the crank gear inside dia might be to big?
I would suggest standing at the parts counter untill they bring all the various ones out for you to look at, sometimes that's the easiest way, just compare them.
Ds7776
06-30-2011 09:16 PM
stewart
07-27-2009 12:14 PM
Bob Lawhorn
02-04-2005 02:34 PM
hotrodmerc
10-26-2003 09:56 AM
