pros and cons of electronic ignition conversion
im starting to get stuff set up for my 1976 ford f-250 4x4, and among other things, it needs a new engine, ive already decided to go with a 390, and i know that trucks of this age use points ignition, my question is what are the advantages and disadvantages of electronic ignition vs. points, and is it worth the conversion? if so, where would i find the best kit? thanks.
get the pertronix ignitor and there coil. The total for both will be under 100$. Its a module that replaces your points, in your stock distributor. I have it and its great. You can get some info on it at:
www.pertronix.com
Or you can get it from ebay like i did, just type in 'pertronix ford'
www.pertronix.com
Brian if your truck is a 76 it should have electronic ignition already 75 was the first year there shold be a box on the drivers side inner fenderwell with two plugs one has two wires and goes into the wire loom in to the cab and the other with four wire goes across the fire wall to the top of the engine and to the distributor if your truck dosen't have it you can use a factory dist. and convert it to electronic Hayes manuels have the complete wiring diagram for the ignition happy hunting
John Workman
76 F-250 Crew Cab 460/C6
John Workman
eladnermai
06-08-2022 10:29 AM
denny7170
11-16-2016 08:20 AM
mudder460
08-21-2016 10:43 AM
eladnermai
11-23-2012 02:04 PM
olfordsnstone
09-19-2005 02:15 PM
1973, 302, 390, 460, conversion, converting, electronic, engine, fleetside, ford, ignition, igniton, points, troubleshooting, truck, year
