'05 F150 FX4 - Transmission Problem
Old 10-27-2005, 05:06 PM
jgm660121's Avatar
jgm660121
jgm660121 is offline
I recently bought a 2005 F150 (new) with the FX4 package. I'm a first time Ford owner. I think the truck is great with the exception of the transmission. I began to notice a knock in the transmission at approximately 2500 miles. The knock occurs when I accelerate after coasting in stop-n-go traffic. When I reported this to the dealer their response was "this is a known occurrence" and "that the transmission is fine". In short, they don't recognize it as a problem and therefore can not/will not correct it. I've owned many cars and driven many more and never had a transmission behave like this before. Is anyone else experiencing this transmission problem?
Old 10-27-2005, 05:22 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
…..See you on the boards.
Old 10-27-2005, 05:36 PM
rileyb's Avatar
rileyb
rileyb is offline
Have them lube the transmission splines where the drive shaft is inserted. This is a known issue. They remove the driveshaft, apply silicon grease to the splines and re-install the driveshaft. The driveshaft has paint-dots that must be lined up with the yoke in the rearend. Be sure to check when you get the truck back. Reference TSB 04-01-06
Old 11-02-2005, 02:02 PM
v10jim's Avatar
v10jim
v10jim is offline
Drivetrain Noise
Yes.... As Described I Think I Have The Same Exact Problem.... Took Mine Back To Dealer And They Serviced All The U Joints On Both Ends Of Front & Back Drive Line.... Still Does It...... I Am Equally Disturbed With Problem.... My Dealer Said Ford Will Not Authorize Repairs & Are Working On A Fix..... Whatever That May Be....
Please See My Other Post Under Drivetrains Noise/clunk...
Thanks
Old 06-10-2008, 11:04 AM
rskullivan's Avatar
rskullivan
rskullivan is offline
I'm having the same problem on my '05 5.4L XLT. when I slow down to take at turn (no complete stop) it seems to clunk when I touch the accelerator. When I do come to a complete stop it doesn't seem to do it.
rnahunter
1997 - 2003 F150
11-30-2023 07:52 AM
MCLFX4
2004 - 2008 F150
29
07-08-2016 09:27 AM
F-Truck
New Member Introductions
09-24-2015 01:55 PM
Mr Stacy A
2004 - 2008 F150
08-18-2009 09:32 PM
Quick Reply: '05 F150 FX4 - Transmission Problem
