Are all 4R70W transmissions the same?
I have a 2003 F150 FX4 4WD with a 5.4 and may have to replace the transmission (4R70W). My question is that I have a chance to get a low mileage 4R70W transmission that is from an F150 of the same year and engine size but is a 2WD. Will this transmission work without having to buy any "kit" or conversion? Thanks in advance.
The 2WD dose not have the 4X4 extension housing and extended shaft.
I have the parts to convert it,(I went from 4X4 to 2WD) Only problem is, The trans has to be totally disassembled in order to put the shaft in. The shaft is the last thing to come out when building a tranny and the first thing to go back in when reassembling it. ):
A higher stall rpm will liven up the standing start.
It will take higher rpm to begin pulling as well off idle.
With the higher rpm, the motor goes higher in it's torque curve before the converter hooks up so you feel it as better acceleration from a stop or low rpm.
It could have some affect on in town fuel mileage from the higher slip rpm before converter hookup.
On the road in OD, the lockup is on so stall speed has no effect.
If the stall speed is high enough, locking up the brakes at a stop and stalling the motor against the torque converter might spin the wheels when the brakes are let off.
Then your a hot rodder hi hi.
Good luck.
Good luck.
There is another way…
The following users liked this post:
78_79ford
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-03-2012 09:54 AM
JRROTH1
04-05-2010 09:11 AM
newfordman
02-17-2010 10:49 AM
TheProfessorofTOOL
07-18-2007 12:58 AM
