Transmission hard shifting
My 01 F250 V10 has suddenly started hard shifting and sometimes taking the RPMs up over 4k when it shifts then drops them back to around 2-3k where it normally drives at.
I have also noticed the OD on/off light flashes when this hard shifting occurs and the only way to stop it from flashing is to stop the truck and turn the key off then start it back up.
The truck hasn't hauled anything in months and only has 30k on it. It is a 4wd superduty. The transmission fluid looks clean and is at the right level.
Any help would be appreciated.
Mike
Mike
Mike
Mike
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I had a similar problem. I disconnected my battery for a few minutes to reset the brain box. When I reconnected it the problem was gone! It has been more than a year. I have since put a code reader to it and I get a "pending fault" for my MAF sensor. I guess I can rationalize that the transmission uses data from the MAF sensor when determining shift points...Whatever....no check engine light, no tranny light....no problems
dieselsubmariner
02-15-2015 10:05 AM
12valveEx
11-03-2014 12:16 PM
