Disc Caliper rattle
Disc Caliper rattle
I recently rebuilt my brakes on a 77 F150 custom . New calipers, hoses, master cylinder, pads but the same rotors. I have noticed that the calipers are loose on the rotors and rattle when I am going over shaky ground. The brake light is on so I am wondering if the proportioning valve could be bad. I tried to the bleed the pv as I have read in some articles. I am thinking that these calipers should be exerting some pressure on the rotor even with out pedal pressure so the calipers remain tight.
Any help appreciated.
Thanks.
Jack
Thanks.
Jack
did you replace the bolt, locking key AND the locking key spring (looks like a small single leaf leafspring) with new ones when you replaced the caliper and put some high temp brake grease on the caliper sliding surfaces?
the calipers should be tight in the bracket, so tight that you have wonder how they can move at all.
Ken_C
08-27-2011 11:59 PM
first today
12-07-2009 09:21 PM
nnypoptart
12-18-2003 12:29 PM
