i've got a leaking and hose problem
the other night when i came home, i noticed that it was raining coolant from underneath my motor. i replaced the waterpump and it's gaskets. now, i think it's called the bypass hose, is squirtin outta both ends where the clamps are. i noticed that the bottom radiator hose goes into this metal type housing and then the bypass hose comes out and into the water pump. can i just run the bottom radiator hose into the water pump (given it clears the fan)? or do i need to run it the way the factory had it set up? thanks for any help in advance!!
rojoraider
15
01-20-2016 03:15 PM
Bread
03-07-2012 10:11 AM
tgore3
09-14-2006 09:38 AM
