How to remove fuel pump
Old Sep 6, 2005 | 03:50 PM
88fordf150's Avatar
88fordf150
Question How to remove fuel pump
Hi,
How do i remove the fuel pump on the frame rail i dont see any bolts????
it seems to be in a sleave of some kind looks like if i just disconnect the Fuel lines and power wires it will slide right out...
didnt want to try that untill i found out if theres any bolts holding it...
Thanks for the help!!
Old Sep 6, 2005 | 04:40 PM
EPNCSU2006's Avatar
EPNCSU2006
There is a bolt on the upper side of the sleeve. Take the bolt out and the sleeve will rotate away from the pump far enough that you can slide it out either end. Be careful with the foam piece, you'll likely need to re-use that on the new pump.
