Square holes?
Square holes?
I'm going to be starting to put new wood in the bed of my truck. I ordered the stainless metal strips which hold the wood down to the frame, etc. The strips came with no holes. I want to take my old strips on the truck and match them with the stainless ones. The old strips have a square hold for a carriage bolt. What's the best way to make these holes or mount these strips? Someone told me the put a thin strip of plywood down first and then mount the oak planks and stainless strips. I already got the stainless bolt kit from Dwayne (Fatfenders).
Ed -
My suggestion would be to lay the old strip over the new. Mark the square holes with a felt marker (for finish size) and then drill the holes to pilot size. Remove old strips and drill out the holes to almost full size. I then would use my "Air File" with a tri-corner file to zip the holes out to the full size square. This tool is from Harbor Freight. It has been invaluable for stuff like this. You could also use a regular file, of course. I used the air file to resize the square holes in my bumper after narrowing it and to size the cutouts for my tail light brackets thru the bedside. Cool tool.
(HF Air File p/n 01704-2HJH, $39.95 + 4 pc air file set p/n 01946-0HJH, $9.99)
I would return them but I purchased them on ebay and it's been over a year and being stupid, I only pulled out a section of the strips to make sure they were OK and didn't even bother to look if holes were punched. No biggy. I just had too many other projects that took priority and I put them with the wood to the side. I checked with Sears tool department and they told me they were fresh out of square drills. Nice try !!!! LOL....
Randy, I'm going to order that file you mentioned. Looks like a must have tool. Then I'll give it go. Thanks for your help.
Ed, I think you have the hidden mounting stainless strips, that is what I ordered and they came with bolts attached to plates that slide into the strips to where you need them to match up with your crossmembers. That way there is no heads to catch the duster threads on.
I hope I made sense. Wayne
Ed -
Sorry about the price hike. I must have an older catalog.
The trick to using the air file is to let it do the work. Take your time on each hole and use light pressure to guide it to the line. Use one of the bolts to check size before moving to the next hole. Yeah, it will take a while, but they'll be perfect. Get the file set too.
Good luck!
Good luck!
Here's my suggestion, do you live near a industrial sheet metal fab shop? Maybe you could take the strips to them and have them punch the square holes on their Iron Worker machine or they may have some other kind of machine that can do the job. I know it won't be cheap but just think of the time it will take you to mark each hole, then drill through stainless, then file stainless and hope everything is in the correct place and shape. I have to drill and cut stainless once in a while for project that either go in food areas or highly corrosive enviroments, it's not a fun job.
I had to drill and file out new square holes on the flanges at the bottom of the fender sides, in 16 ga carbon steel. I drilled to 5/16" in steps, then used a square hand file. It goes surprisingly fast, but that is in carbon steel and only about a dozen holes. I think it is going to be really difficult to file SS that is work hardened like those strips. I'd go with getting them punched for sure.
SS is a LOT harder than mild steel and will dull a drill bit in a hurry! I burned up a brand new bi-metal holesaw blade trying to cut a 2" hole in the bottom of a 28ga SS pet food bowl. I could not get a standard HS drill bit to drill the small screw holes I needed in it, so I ended up using using a solid carbide rotary burr with water cooling. It will dull a file as well. I vote for the punch machine. If you can't find someone with a punch machine then drill the holes oversized in the metal the size of the diagonal of the square under the bolt head. Drill the bed boards the size for the bolt shank, and pull the square part down into the wood as you tighten the bolts. No need to cut squares into the wood.
